oil leak
ccrunner1
virginia beach, va
alright so after i made a 250 mile trip through the mountains. i discovered that i am leaking oil from what appears to be the drain plug.
  • it only leaks when its running
  • the oil guage is reading around the L in "normal"
  • i took it to a hole-in-the wall oil exchange, they said it was tight and not to worry
  • could the O-ring or pan be cracked?
  • what do i need to do before i drive back home on the 24th?
I change oil 6 days a week. more than likely you have a stripped drain plug or you need a new gasket on it. I see it all the time
i agree with shawn get yourslef a new drain plug and see if that doesnt help with the oil leak
$ 2.99 at autozone. Plus New oil filter and oil of course.
