Oil Leak
budgettruck
Is it common for the 3.0 to leak at the rer main seal. The only reason I ask this is because I recently put the motor in and changed all the gaskets including the rear main with the Fel Pro kit. I had a hard time getting it to go in, just wanted to see if anyone else has every experienced this problem.
Mine started keaking some around 50K miles. The dealer said "It ain't that bad yet." I replaced it with a clutch replacement.
I discovered mine leaking at 45,000 - I'm pissed. So much for quality at Ford.
