I am working on a 90 B2. It seems like there is insufficient oil flow to the right side of the engine. The lifters don't seem to be staying pumped up, and there seems to be very little if any oil in the rocker shaft.
I have checked the oil pressure with a gauge and it is running at 45 - 50 psi. I had just replaced all the lifters because #1 exhaust was collapsed. When I crank over the engine with the rocker rail removed I don't see any oil come out of the feed hole to the rocker shaft.
Is there a place to find an oil flow diagram? Does anyone have any ideas where to start, or troubleshooting techniques?
Thanks
Thanks
