nooberiffic
- May 21, 2009
So, I have a new 4.0 in my truck. Did the first oil change at 500 miles. Did the second at 3500 a few weeks ago. Using mobil 5w30 synthetic.
Here is the problem. When I pulled the oil drain plug the second time (no issue the first time), there was a bit of white film over the end. The oil was dirty, but no trace of coolant or anything. I also changed the PCV valve and there was a bit of gunk on it as well.
I am not loosing coolant (as far as I can tell, its always filled to the top when I check it).
The oil pressure idiot switch on the dash always sits at around ORM, rock steady, usually halfway touching the R. So, yay, 8 PSI is all that means. So, after I changed the oil the second time, it sat at NO, would kick up to OR, then back down. This happened a few times the first couple minutes, then it went back to normal (at ORM) and has held steady with no problems since then.
WTF? Anyone have any ideas about either of the issues?
BTW, its the winter so there is a bit of visible exhaust that comes out til everything warms up, then it goes away. Also, when checking the dipstick, oil looks clean. Maybe one or two tiny speck sized bubbles. Thats it. No gunk on dipstick, no white gunk on oil filler cap.
