sce Thor
- May 4, 2014
- Automatic
I have a '02 Ranger 2.3 DOHC that has been running rough. The engine has been loping.
Engine code is P0171 Lean Bank one
Also has a code P0310 (think) misfire on cylinder one
I have checked the MAF -good, TPS - good, IAC - good, plug wires - good. Also replaced Ho2s - upstream sensor. Nothing working.
Replaced the Fuel regulator hose as well
Getting a rich burn and smell from the exhaust.
In the process of checking the wires and plugs the #3 plug was coated with oil. I mean dripping once out of the well. I looked down into the cylinder and saw nothing but oil. There was oil around the base of the plug prior to pulling the plug as well.
Thinking that this may be a bad valve seal leaking oil, and oil getting blown up past the spark plug.
Any ideas? I would have run out of patience awhile ago but this little truck has been very good to me. With 131k and this is the worst that has happened. I consider myself pretty lucky.
