1pokeyRanger
Hey my oil gauge wiggs out sometimes at idle - flickering up and down rapidly. If I give it a little gas it smothes out fine. Ideas?
Locate your oil pressure sending unit and replace it with an aftermarket gauge. That will tell the real story with your oil pressure. Senders do go bad, and some of these fords came with what's basically an idiot-gauge. Meaning if it has more then 5or so lbs of oil pressure? The gauge will always read mid-range unless there is an issue. If your engine is worn, and the oil pressure is floating around that safety point? That would cause the gauge to wig-out.
Aftermarket gauges can be installed with a "T" adapter so you can use both the dash one, and the aftermarket one. (that's how mine is installed....when the idiot gauge reads at the "A" in "Normal" at hot idle in drive? The REAL gauge is showing 10lbs of oil pressure..)
S-
+1
What T-Bear said!
Thats the only way to truly know whats going on with your oil pressure. I'm thinking from your description of the problem that your pressure may be dropping below or right at 7 psi (I think thats what it is). I strongly suggest installing a mechanical guage to see exactly what you got. At hot idle I'm at 20 psi using 10w40.
On a side note: T-Bear what weight oil do ya use?
