oil filters.
ranger
Pittsburgh,Pa
I just wondered what oil filters everyone runs. i heard not to use fram just wanted to know what everyone else thinks the best filter is.
motorcraft is what i use usually...
motorcraft fl1a. thinking about doing an oil bypass filtration system tho with a better filter.
Motorcraft on the family Fords, AC's on the family GM's, NAPA Gold on the Jeep.
my 2.9 has always used napa gold.
my twin turbo 300zx only uses OEM nissan.
ever seen a cut up cheapo filter? junk paper filter, cheap spring, bad flow, not where i'd id cut a corner
All of our fords get Motorcraft, my brother uses Fram on his XJ.
Wix or NAPA. The Napa filters used to be a Wix with the NAPA name on them. Not sure if that's still true.
I've always run Motorcraft, occasionally there is a promotion at the local O'Reilly Store. (5qts of Mobile 1 with a Mobile1 Filter for cheap).
