- Dec 3, 2016
- riverview, fl
- 2.9 V6
- Automatic
- Total Lift
- none but it is a convertible
- Tire Size
- stock
i am planning on using the oil filter mount from my parts 2.9 as a hydraulic filter on a tractor i am repowering. it originally did not have any filter. i need to know which way the oil flows. i think it goes from the oil pump to the center of the filter mount and exits the filter at the off center hole. am i right? i once reversed the oil lines on a remote mounted filter on a 2.8 with catastrophic results so i want to be sure this is right. also, is the threaded part the filter screws on to metric or sae?
