rangerrj
- Sep 27, 2008
- Automatic
Had my 2004 Ranger 4X4 in the local Ford shop yesterday for new tires and to check out a brake issue. I had them change the oil and filter since the truck was there in the air which is a job I normally do myself. I was looking at the bill after I got home and noticed that I was billed for 5 and a half quarts of oil. The 4.0 takes 5. I went out to the truck and pulled the dip stick and the oil level was right at the upper hole in the dipstick which is way above the hash marks by a good inch. I always thought that the oil level is suppose to be between the upper and lower levels of the hash marks. Before I yell at somebody, can somebody confirm my belief? The operators manual is confusing as it shows the hash marks between the two holes with no empty space between the hash marks an the holes. Dipstick is the original one. I have a couple of GM products which are different of course. I always use Motorcraft filter and 5 Qts. of oil after I let the pan drain for at least an hour. Can anybody confirm where the oil should be before I drain half a quart out?
