krambjas
Ok, this saga has been going on for a while, so here's the story:
Quite a while ago, my 1989 Ranger 2WD, automatic, with a 2.9L V6 developed an issue where the coolant would drain into the oil pan. I'd fill the radiator, let the truck sit, and a week later the radiator would be empty and all the coolant was in the oil pan.
So, assuming a blown gasket somewhere, I took the engine apart. I replaced every gasket in the engine: heads, intake manifold, exhaust manifold, front cover, water pump, and oil pan. It was a pain in the ass since I did everything with it all still in the truck, but I got it all apart and put it all back together. It started up on the first try and seemed to run great. A week later, all the coolant was in the oil pan again.
So I pulled the engine out of the truck, figuring I did something wrong and that it would be easier to do it right with more room. It sat for a while as I was working on other projects, but I eventually got back to it. Tore the entire engine down to the block. Cleaned everything off and looked for issues as I went about putting it back together. I replaced every gasket in the engine again, but checked for leaks as I put every part on. So I put new head gaskets on, torqued up new head bolts, plugged the coolant holes in the block, and filled the block with water. No drips or leaks. Did the same thing after I put the intake manifold on (and actually had a leak the first time I did it), and the front cover/water pump. Plugged all the tube opening in the water pump and filled the engine with water again. Nothing. No leaks at all.
So I put the engine back in the truck. Hooked everything back up. Once again, engine starts up first time. Everything seems to run great. I drive it around for a bit to make sure things work, no issues other than a needing to tighten up a couple hose clamps. Checked the radiator once more to make sure nothing was wrong and everything looked ok.
I left for work for a few days and left the truck to sit. I checked the radiator last night. Empty. Dipstick has cloudy oil and is overfilled. All the coolant is once again in the oil pan.
I give up. What wormhole have I opened up that would allow coolant to end up in the oil pan when the cooling system is not pressurized (remember, I opened the radiator to check it before letting it sit) and when all gaskets are new and were checked for leaks? I'm at a loss.
