lorenambrose
Should I bee worried about consuming 1 qt of oil every 3000-3200 miles? There are no leaks anywhere.
The truck has 62000 miles on it.
With an actual 62,000 mile count YES I'd be worried about that much oil comsumption. Did you purchase the vehicle new? If not then you should look to see if the milage has been set back. Or if the engine has been overheated and the valve seals have went away. I wouldn't expect that much oil loss with 162K on my engine.
Big JIm
being that severely overheated, it probably needed a full rebuild.
i don't know if i would believe the dealer, because oil doesn't just dissapear. i would think being so overheated really beat up the cylinders/rings, and now its burning the oil slowly. like said above, check the PVC system, and also open your radiator cap and see whats in there...
On that engine I would be concerned.
Did the stealership really do all those tests? Were they documented? Is there paperwork showing the leak down test on all cylinders?
Do your own compression test, overheating affects more than just the heads. It's the whole block.
Pull your plugs, burning oil fouls them up.
Does it smoke? On start up? driving? Idling?
Is there any oily residue on areas beside the oil pan? Like on the trans, frame, cross members, starter, side of block, valve covers, etc? Oil on the frame or cross members behind the oil plug could mean oil loss during driving.
Well I can not find any leaks and there is not even a hint of smoke under any conditions. No detectable odors either. The plugs have been pulled and they all look ok and pretty much the same. Nothing sticks out.
Yes all those tests were done and the lowest cylinder's compression was still about 90% of the highest cylinder.
I am torn about the severity of this. From a glass half full perspective, it is less than 1.9 drops of oil per mile. I just don't know.
The compression should be no more than 5% that 10% could very well be the issue was the engine full of oil when it overheated sounds to me like a rebuid or rebuilt is in your future.
