oil and fuel mix?
Use a mix of oil and gas as a starting fluid. Prevent it from seizing friend did that to a weed eater one time. 32 to 1 is 8 ounces per gallon btw. I would use reg oil for now and until it starts running right before switching to 100 to one synthetic.
Run a 30:1 to a 40:1 to start with. My 73 JD600 and 80 Jag both require 40:1.
You'll have to pull the carb off and pull it apart. Check to make sure the gaskets have not dried out or gummed up. My need to look around for a set of gaskets for the carb. With it being a 71 I'm going to assume the fuel pump is in the carb. There would be like 8 gaskets to the carb.
ok....i will pull it off tomarrow and see what i can find.....it is the twin cylinder!...hopefully i can get thing thing going!!!
Check to make sure the exhaust manifold is tight before you go rebuilding the carb...I have an older snowblower that died suddenly and would not start...went to a small engine rebuilder and, fortunately, he was too busy to even look at it...he suggested the carb needed rebuilding though...
When I got home I found a long screw fell out into my hand when I was trying to drain the carb...it was the exhaust manifold bolt (one of two) and when I tightened it back in place the engine ran fine...
That's how I know backpressure is important to some engines...I think!
Backpressure is VERY important with 2 strokes and in some cases resonant sound waves also play a part in the efficiency of the engine. That pressure is used to keep your air/fuel mix inside the cylinder during that brief period of time when it is exposed to the exhaust port right before being ignited (during the upstroke).
Rebuild your carb. Since it's that old it needs it. Just general maintenance. Also make sure that the exhaust isn't plugged anywhere. This is insanely important especially if there is a piece of metal screen in the exhaust somewhere. They get clogged with carbon really fast and fuel mixtures rich on the oil side will contribute a lot to this.
if its a single cylinder it won't have reeds, when I had mine i had the same problem and it turned out to be water had gotten into the carb and popped a welch plug loose. I ran 20:1 and I could run it for almost two seasons on one plug. it was a tank, slower than death but fun to ride.
I've owned couple single cylinder engines with reed valves...actually a lot of older outboards have them and so do Weed Eater brand equipment. Those are just some examples that come to mind. Been a while since I worked on small engines...used to be hardcore into that shit.
rebuilt it...looked nasty....now need new fuel line...the old stuff broke :( i thing after an other with this
