OHV Timing chain PLEASE HELP!
jrny4rbys
Forum Member
South Mills
NC - USA
Vehicle
Drive
So my son and I have been very slowly working on his Ranger. The weather and life just hasn't made it easy to get to. Anyway, we finally buttoned it up today and it's not running. We did the timing chain components (we were already there, so why not) and the camshaft synchronizer and valve cover gaskets. So, after the truck wouldn't start, I was doing some digging. I think we installed the top timing cam upside down.
The only video I could find on the webs doing a timing chain replacement on a 4.0 OHV had, with cylinder 1 at TDC, the bottom crank key at 12oclock. The top cam had the dot also at 12 o'clock. (see video screenshot). This is what we followed.
But, and I can't find this but in one place - (on charm dot li) - I found a picture that shows, with cylinder 1 at TDC, the bottom crank key at 12 o'clock and the top cam with the dot at 6 o'clock! Please don't tell me we followed the only video we could find on this and it was wrong. (see screenshot of drawing)
Please help - do the dots point both at 12 or bottom at 12 and top at 6.
I have a feeling you did it upside down. Not the 4.0 but other engines I've done the dots were always close together.
Well, I was hoping i had a picture while my engine was apart but nope.
It's crazy. The video we found was a 4 part series on just this motor. It was very well done. So we followed his steps. It's so hard to find good solid info on this motor.
I think you are right @alwaysFlOoReD . I think he (and therefore we) put them upside down (both dots at 12). The drawing screenshot is supposedly out of a Ford manual. I'm assuming they mostly know what they're doing!
I newly have access to the snap on online database. PM me and I'll get you the correct info.
@jrny4rbys
Event Coverage
TRS Merch
