- Dec 4, 2025
- Pendleton
- State - Country
- SC - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 2.3 (4 Cylinder)
- Manual
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- 235/70 R15
That's what my best friend said when I bought it and realized that it actually does need some work!
Hello everyone! Iām Dustin from Upstate South Carolina. My 2008 Ranger started out as a simple, inexpensive daily driver and something reliable to get me around without much fuss. At the time, I figured Iād keep it mostly stock and only handle basic maintenance.
That didnāt last long. What began as a budget-friendly pickup has turned into a steady project. Between repairing previous-owner āsurprises,ā sorting out electrical quirks, updating the audio system, chasing down suspension details, and planning a few OEM-plus improvements, the truck has become more of a long-term build than I expected. The costs are adding up, but itās been worth it to bring the truck back into solid shape and make it my own.
I really like it as it is. It's pretty nice body-wise, with only a couple mild issues that a PDR guy could handle. The previous owner had LED headlight bulbs installed. Those went the moment I had an opportunity. I do have plans to swap out all the bulbs to LED and run a no-load flasher, then rebuild the headlights, integrating a pair of semi truck LED headlight housings that are truly DOT rated.
However, repairs are needed:
- VC gasket & PCV (purchased)
- Engine & trans mounts (got 'em)
- Spark plugs and MAF clean
- FULL TRANSMISSION AND REAR END REBUILD...
- New General Altimax RT45 white letter tires in 235/70 15 (I know, not a stock size, but it's closer to OEM OD running the Ultra 15x8's that came on the truck).
Then upgrades:
- Front to rear complete Energy Suspension bushings upgrade
- Steering rack replacement w/ filter upgrade
- Rear aux hitch/reverse lights (a post for later!)
- Adding fog lights
- Adding driving lights
- Toolbox to trunk project with added lights
- Audio system install with sound deadening in the doors and roof
- LED interior and dash lights with semi-truck red under-dash lights to illuminate the cupholders
I'm sure there's more, but I'll post all of it here whenever it gets done.
Then upgrades:
- Adding fog lights
