Official A4LD Problem Thread!
Just follow the post in the technical forums, the hardest part is getting all the parts, also unless you find a ecu from a 5 speed with your engine size, your check engine light will come one and stay on.
I have most of the parts that I have been collecting for over 6 months now, I plan on changing my 89 BII from a auto to manual.
Robert
The check engine light will stay of, then only thing the computer dose is control 3/4 shift and tc lock up, manual computer would be better though because it holds a high idle for a sec when the clutch is depressed for a smoother shift, been there, done the m5od swap now back to a4ld now after blowing 3 m5ods
Sent from my SCH-R830 using Tapatalk
Would also like to add ran both auto and manual computers with manual trans, if I remember right the auto computer made the engine idle at about 1000 rpm but I'm thinking that was because there was no torque converter to "lug" it down at an idle
I had to clean my governor to get it to start shifting into second when cold. Works fine now...If it does hang up, I can run it in 1st then around 2500 put it in drive. Then it's unstuck and works fine.
My fluid is dirty. I need to change it and filter but it honestly worries me a bit to do it. Fresh fluid might wreak havoc, I dont know...
Ok, that's what I was kind of leaning to, checked vac mod last weekend, adjusted bands and a fee other things and nothing. I'll try cleaning gov this weekend and see what happens
Try running it in 1st and bump to Drive. It will usually unseat it. Chances are though, you will need to drop the TC and clean it out. Super simple to do just make sure you fill it with the correct fluid and have black RTV on hand for the TC / Tranny.
Been manually shifting for now and been doing good, if I shift to drive too soon it will rev up like it hit neural, drop back to second and grabs right away then I can get drive
Good (in a way). Sounds like you also just have a stuck governor. See if cleaning helps. If your fluid is as dirty as mine, It could be causing it to stick.
If youre brave enough, go for replacing the fluid and filter.
I'll do fluid and filter, did it about 50,000 ago when I got the trans and it had about 125000 on it and she's still going strong except the hopefully sticking governor
Good. I have no idea how old my fluid is. I've had the truck for about 60k and it was dirty then. It's got almost 200k on it now and I got it at 130k.
You might still have to go in there and clean up the governor but at least you know the governor and fluid change will help....For what it's worth, I'd look into getting a 35mm weight for the governor. Just google A4ld Governor 35mm weight and it'll come up. its about 8 bucks and it'll unseat the governor if it ever gets stuck again. The bigger weight helps keeping binding at a minimum anyway.
Ok I'll look into that thanks for the tip
Well turns out my feeling that someone else was in my tranny before I got it was right. The gov valve is not there just the spring and counter weight are there. Guess it's looking like ordering a new valve
You'll find that there are a few Gov valve styles out there. Mine only had 1 groove so you're should also be a one groove Gov.
Where did you find it? I've looked for over an hour and haven't found one yet
Sonnax Part Numbers are below. I got mine from wtttrans.com
U56680A Governor, A4LD (Small Land On Valve Is .385OD) (Valve Has 1 Groove).
U56680AA Governor, A4LD (Small Land On Valve Is .385OD) (Valve Has 2 Grooves).
U56680AB Governor, A4LD (Small Land On Valve Is .385OD) (Valve Has 3 Grooves) .
U56680B Governor, A4LD (Small Land On Valve Is .326OD) 1990-95 3.0L.
U56680C Governor, A4LD (Small Land On Valve Is .314OD) (Valve Has 1 Groove).
U56680CA Governor, A4LD (Small Land On Valve Is .314OD) (Valve Has No Groove).
D56681-1 Governor Body, A4LD (Small Land On Valve Is .314OD) 2.3L 1989-90.
S56681-4B Governor Weight, A4LD (35mm OD).
The items i bought were in bold. You should check your parts before you buy to make sure you're right.
I have a 94 B4000 with the A4LD, and the torque converter is staying locked all the time when in 3rd and OD, when coming to a stop it bogs the engine down a lot, until it shifts down to second. I am trying to figure out where to start the troubleshooting. Any ideas?
UPDATE 1/28: Problem fixed! I found a wiring schematic for the 3-4 shift solenoid and TC lockup solenoid, and tested wiring. It was getting a constant ground. I disconnected the computer and the plug on the trans, and tested the wire. It was grounded, so there was a short in the harness. I ran new wiring to it, problem solved!
Event Coverage
TRS Merch
