sledneck07
- Dec 13, 2009
- Manual
Just follow the post in the technical forums, the hardest part is getting all the parts, also unless you find a ecu from a 5 speed with your engine size, your check engine light will come one and stay on.
I have most of the parts that I have been collecting for over 6 months now, I plan on changing my 89 BII from a auto to manual.
Robert
The check engine light will stay of, then only thing the computer dose is control 3/4 shift and tc lock up, manual computer would be better though because it holds a high idle for a sec when the clutch is depressed for a smoother shift, been there, done the m5od swap now back to a4ld now after blowing 3 m5ods
Sent from my SCH-R830 using Tapatalk
