Off Idle Issue
RonSerling
High in the mountains of San Bernardino National F
ummmmm 4" could be 6 but its a TTB and the little bugger varies from time to time !! LOL
Good day all,
I have a 99 Ranger 4.0 with a issue I am looking to get some advice on. It seems as we had an vacuum leak issue which we found and repaired the other day. It was idling around 1200 and would not settle down. As I said we found the issue and repaired it but now there is a new problem that has come up. When the engine is running it idles fine and if you hit the gas pedal hard it revs up fine. If you very slowly press down on the pedal it starts to stutter and some times it will stall out. I removed the throttle body and gave it a good cleaning but that did not resolve it so before I go poking around again I am wondering if anyone else has ever had this issue and what was the cause ??? I hate wasting time and would prefer to hear from someone that has already figured out this issue so I can get it fixed and over with. Any info you can provide would be greatly appreciated as I have asked a few questions here before and gotten some really good help !! Thanks
No codes !! Checked that yesterday !!!!
Use a analog voltmeter and check the TPS (throttle position sensor)...it may have a dead spot in it. There are instructions on the main page (i believe), if not, google is full of how tos on the subject.
You know I was thinkin the same thing !! Great minds think alike. On the list of things to do today !!!!!
