so i've been noticing for quite a while that upon startup especially when cold, my truck has been making 2 very distinct noises, the first is when the engine is cold, over night or sitting 8 hours while i'm at work, and it's upon start up for about 2-4 seconds, it has this chirping, kind of sounds like a cricket, but not quite so high pitched, if i shut the motor off right after it starts, it will chirp till the motor stops spinning, and will do it again if i re-start, i could potentially make this noise by starting and turning off the motor repeatedly, for quite some period of time. it does NOT do this when the motor is warm
the second noise is a hydraulic sounding hum or buzz out of the motor, it sounds a LOT like a forklift's hydraulic system, or a tow truck's, that whine that you hear. This whine is ONLY present upon initial startup in very cold tempatures... the days where i HAVE to start my truck up before leaving, i start it, and it starts this whine, and continues it till i am back inside the house... when i come back out to drive off, it is gone though... recently the tempature has been down to -30 in the morning on some days and over the last week we have had highs of -15, and it's only happened a few times...
we usually have a month or so of -40ish weather, sometimes hitting even colder than that, coldest i have seen was -50sometihng i think it was... frost bite sets in to bare skin in minutes
fwiw, my coolant was tested yesterday, and was rated at -40
