OBD-ii codes for Flex-Fuel (composition) Sensor output?
fixizin
FoMoCo is forcing me to buy a 'yota
Ft. Lauderdale, FL
3.0 V6
P235/75R15
A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
I know there's a xx706 code if the ECM reports a malfunction with the infamously-eh-spen$ive FlexFuel sensor, BUT... is there a real-time output, similar to the fuel-trims, etc, that basically tells you what % ethanol it's sensing? :icon_confused:
The answer, apparently, is nay whinnie, no. Bummer.
Forscan, a diagnostic tool, gives you the percentage of alcohol in the fuel.
Forscan... NOT gonna say what it ALMOST sounds like... but will check it out!
(Drill Sergeant: "Platoon! Fall out!... short-arm inspection in 5 minutes!...") ;)
