Obd 1 code 224
Lou58
Chesapeake VA.
Check engine light came on scanned truck came up with code224 changed primary coil , plugs and wires cleared code check engine light came back 224 what else can be checked. Any thoughts would be helpful
Lou58:beer:
heres what 224 is.
224 (M) Failure in ignition coil primary circuit - Ignition Systems
so it may not be the actual coil. check the power going to the coil
Checked power to both coils at the connector got 12v , checked the resistance at 1&4 , 2&3 got 13.38 ohms on both packs. Whats next?
Thanks Lou58
