O2 sensor simulator
86harleyd
Conway Arkansas
I have a 1998 ranger 4cyl 5 speed I just purchased the previous owner has removed the catalytic converter. (yes I know it is against federal law, however so is removing the tag from a mattress) I live in a state that does not require a vehicle inspection. Now that I got that out of the way. I have the check engine light staying on and coming back on after I reset it due to the down stream O2 sensor. My question is where can I buy a O2 simulator to bypass this problem or is there any other solution besides removing the check engine light bulb or putting on a new catalytic converter. This is for off road use only on the farm.
Thanks
Well... since this is for farm use only, I'll PM you the info rather than leave it out in the open.
