spraymonkey
- Feb 28, 2012
I have a 96 ford ranger 4x4 xlt with a 4.0, My issue is the CEL with codes
P0153, P1151.
The maf has been cleaned, has a new fuel filter and it seems to run just fine, Im thinking it is the 02 sensor itself because the CEL will turn on for about a day or so then go off for another day or 2 then turn right back on. Not sure if anyone else has had this problem but i could use some insight on what i should be looking for, oh and i have also checked for vacuum leaks and found none.
P0153, P1151.
