MarcosLopez77
- Feb 21, 2013
1991
Im in the process of doing a 2.9/4.0 conversion. The Y-Pipe from my donor Engine (98 ranger) has 2 O2 sensors. Where the Truck that its going into
(1990) has wiring for 1 O2 sensor.
My plan is to seal and weld the ports for the 2 O2 sensors and drill and weld a new bung where the 2 pipes join in the y pipe. This would eliminate the 2 O2 sensors and work with the wiring I will be using.
My question is has anyone done this before and if so did this work for you? did you run into any issues doing this?
Is using a y-pipe from an earlier model with 1 O2 sensor a better route than this one?
