2.3L ('83-'97) O2 sensor, P0196 code
moretsky99
Forum Member
Pensacola area of Florida
FL - USA
Vehicle
Drive
14"
Getting code P0136, Replace Oxygen Sensor(s) (O2S), O2 circuit (Bank1, Sensor2).
I am getting a check engine light, but have not noticed any engine issues. It seems intermittent.
I'm confused about which sensor. Should I just replace the one on top of the catalytic converter?
Other O2 sensor posts sometimes point to different issues on this site.
Looking to order from RockAuto, but don't want to get the wrong part. They have a
"WALKER PRODUCTS 35034414 OE Replacement Info One of our most popular parts
Fits Upstream; Bank 1 Sensor 1
or Downstream; Bank 1 Sensor 2"
for $23. Does this mean it will fit either and will likely fix my problem?
Bank 1 is whatever side cylinder 1 is on, bank 2 is the other side.
Sensor 1 is before the cat, sensor 2 is after the cat
So you are having problems with the after cat sensor for bank 1. on that vehicle there may only be 1 after cat sensor for both banks, I couldn't say off the top of my head.
Note, it could be a bad sensor, but it could also be a problem with the cat itself.
Being a 2.3L there is only one bank so it is talking about the rear sensor so yes down by the cat
I don't know P codes but I'm sure the description doesn't say replace O2 sensor, that's likely what a "fix finder" says, but being it's a '96 it's probably factory so wouldn't be out of line for it to be a bad sensor.
P0136: O2 Sensor Circuit Low Voltage​
I'd look for wiring melted first. O2 sensor wires have a tendency to get against the exhaust and melt.
I had a rear O2 code on my '97, might have been that one... I just got lazy and put in a spacer thing and it's been fine since...
I posted a video here on the site some place about the sensor. Now that I know what it does, that makes sense. You must have had a air leak where you put the spacer or you knocked some sense into the sensor so it worked again??
No, it is just tricking the sensor since it now receives a filtered signal... the sensor is still the stock one and I didn't feel like buying a new one or investigating further so I put in a $5 spark plug antifouler... the catalyst was compromised at one point with cracks all over the can that are now welded up. The code I was getting was something about the rear sensor seeing switching when it should be a stable voltage if the catalyst is working correctly. At 250k it should probably get a new cat but meh...
