O2 sensor help
poomero
Oregon City
What’s the trick to changing the passenger side manifold o2 sensor?
I can reach the electrical clip to swap it.
I cannot speak from actually changing one but have removed mine for other purposes. What I've found in mine is it takes a wrench to fit, and some time
I think it's a bit over a one inch wrench you'll need which can be found at pawn shops and yard sales on the cheap
The electrical clip is just behind the engine. You should remove the entire splash apron in the inner fender to get to it. You cannot reach it with the apron in place. The apron is held in place with plastic push pins.
You will need a small screwdriver for the sensor connector tab.
For me the larger problem was that the sensor wouldn't budge from the exhaust pipe and I had to take the truck to a shop to get the work done. I had the shop replace both O2 sensors on that side while it was there.
Thank you. I will remove the splash guard and see if I can reach it.
