o/d button removed nothing works
Wsljr2208
i removed the o/d button from the end of the column shifter to put a different shit knob on and now thw abs,brake light are on and turn signals aren't working do i need to relocate the button for all this to work or is there a way to bypass it i never use o/d so deleting isnt a problem and advice will help
its an 04 ranger auto 3.0 2wd for what its worth
Sent from my S60 using Tapatalk
Check fuse #20, 10amp, in the cab fuse box, passenger kick panel
You may have shorted the OD wire and blew that fuse, this fuse also powers the other effected systems
The button does not need to be hooked back up, but its wire must be taped up so it doesn't short out.
When you turn on the key the computer will reset to OD on, the OD button is there to turn OD off when going up a long grade or when pulling a trailer, so no shift to 5th gear which keeps RPMs up.
Each time key is turned off and on computer resets to OD on
You may have shorted the OD wire and blew that fuse, it also powers the other effected systems
that was the first thing i checked i pulled one wire at a time and temp taped them so that wouldnt happen Hazzard lights work ignition works currently driving havent plugged it back in could it be wired together somehow
No, the OD button just has 1 wire in(12v from fuse #20) and 1 wire out to Computer, if computer "sees" 12v monetarily on that wire then it turns OD off and activates the dash light, if it "sees" 12v again then it turns OD back on, so it toggles with momentary 12v pulse.
OD button is always disconnected, unless driver uses it, so no connection to the other systems
Something else in the column wiring was disturbed
the only thing I did was pop the end off the shifter didnt open the column is there anything else i should check and thank you for the fast response and help
Nothing comes to mind
