- Sep 5, 2008
- Gardnerville, Nevada
- Manual
I am rebuilding my front end on my ranger. Looking for what size the bolts are for the radius arms and axle pivots.
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
What about the large bolt on the end of the radius arm? And do you know about the axle pivot bolt?Axle pivots are 14mm
Lower radius arm bolts are 3/4 and upper bolt/studs are 3/4 and 5/8
Sent from my SAMSUNG-SM-G920A using Tapatalk
Any other special tools I need besides some impact socks and a ball joint press.The nut on the end of the radius arm? 3/4
A propane torch to soften and release the Loctite Ford puts on them, particularly on the radius arm-to-axle bolts.
X2 with the heat!
I rounded mine off, ground it down to the next size, rounded that off, ground it down again and broke a 1" box end wrench.![]()
How hard is the job to do without removing the radius arm from the axle?
We're did you find these bolts at and the actual name of them cause my buddy kept calling the the radius are bolts which clearly its not cause ive searched everywhere and nobody could tell me anything and these are exactly what I been trying to find thank you all accepting meWhat about the large bolt on the end of the radius arm? And do you know about the axle pivot bolt?
If you’re talking about the stud that goes through the bushings on the radius arm where it attaches to the frame, that’s welded to the arms.We're did you find these bolts at and the actual name of them cause my buddy kept calling the the radius are bolts which clearly its not cause ive searched everywhere and nobody could tell me anything and these are exactly what I been trying to find thank you all accepting me
