Denisefwd93
- May 20, 2015
- South East PA
- 4.0 V6
- Total Lift
- stock, may get leveling springs in front "somday"
- Tire Size
- 235
So.. still doing my "homework" on this auto to manual swap we are planning in the spring. Everything keeps coming back to the newer (1998) M50D not having the NSS; neutral switch (or whatever you want to call it)
My truck is a 1993 with A4LD and 4WD (electric Tcase)
I will be getting the PCM for a 4.0 manual shift truck.
I know the T-case needs neutral for 4W low. I know I need the NSS to pass PA inspections also. Starting in gear can be good at times but it's mostly a bad idea most of the time.
Of course I'm bit miffed since this little switch is so important to make things work like someone "knew" what they were doing.
is finding an older M5OD what I need to do?
This tech page... http://www.therangerstation.com/Magazine/January2011/M5OD-R1HD_swap.htm but he had the manual in his truck and just left the NSS unplugged since he didn't have one on the newer trans.
CAN.. the older top trans cover with both switches fit on the newer trans?
thanks for help in advance!
