ok.. heres the deal this is an 87 2.9 auto 4x4 no ac... it will start up "sometimes" and appears to run fine but then it starts loading up and running real rich. now hit the gas and it seems to clear up for a bit. i noticed the fuel pump never stops when the key is just in the on postion, should it build psi and then stop til i start the truck? ok so here is what i know took it to 2 different guys nethier helped me on said all my sensors checked out good but there was low engine vacume he thought it may have jumped time but i thiught it runs pretty good to have jumped time. someone help me i'm not going to take it to another grage i am just going to fix it myself... thanks rob
you may have several things...when was the last time it was tuned up??, meaning plugs, wires, filters, cap and rotor.
yes, your fuel pump should prime the system then shut off after 2-5sec...without starting. a fuel filter is good place to start.
you should try to get codes...the tech Library here, show you how.
I was able to get code run at my local parts store...(for free). You may want to try at your favorite place.
as far as the sputtering and inconsistant starting goes...this is where you may have several things happening.
you may have a bad TFI (aka ignition module), and or, fuel pressure regulator (FPR), and or, vacuum leaks. combination of any of these things will make it run pretty crappy, with simular results as yours. then again the earlier mentioned tune up can too.
getting the codes from your engine computer will have
a lot to say about what your trucks issues are & help you zero in quicker.
TFI is on the back side of the distributor cap, with a special tool it can be removed and check , again at most parts stores.
FPR; a quick check is to remove the little vacuum line on the back side & see if it dribbles fuel out...if so, it is bad. IF it don't leak fuel, doesn't mean it is good either , then testing with a fuel presure gauge is best.
the
vacuum leak can be found (ususally) by systematically spraying carb cleaner along the upper intake hoses and mateing surfaces (while it is running), if it pick up rpm or smooths out then, that is a suspect area.
well, that a place to start
