Note for wheel page
UrbanRedneckKid
Solid Axle Swap
Cass Co, Missouri
Stated on the wheel page in the library, 98+ wheels won't fit on TTB trucks.
True, but with one exception, the FX4 Level II Alcoa wheels. They are even pictured with the Warn hubs in them. I took that pic btw, I will miss those wheels. Too bad they don't fit a D44.
Just my two cents, Thomas
The wheels will fit, but you have to have the hub center cut out by a machine shop to fit over the hub.
Are you referring to his comment about the FX4 wheels, or the 98+ wheels in general?
All '98+ RBV wheels center bore is too small to clear the manual hubs on the TTB RBV's. I have tried the FX4 Alcos on my '97 and they didn't fit on the front.
OK. So noted.
That pic is proof they fit on TTB truck. That's my 06 Alcoa, mounted on the left front of my 94, with a Warn hub, which is the same as your 97. The only difference between the two is the brake calipers, which are the same size.
They wouldn't fit over my MileMarker. Maybe '06 had a larger hole because the ones I tried were '03s.
