Hypnotic Toast
Well, this is kind of a two part problem. This all started with my truck having problems shifting into the drive gear. From park to drive, it would act like it was in neutral and not move, then it would jump into drive and lurch forward after a few moments. But if I went from park to my first or second gears, it would act fine and drive AND if I went from first or second to drive it would shift fine. So it's just from park to drive. And while driving it has no problems shifting through the gears or being in reverse.
Now it seems that my back left wheel is locking up. It doesn't matter which gear it's in, in won't turn or roll. I have to have the truck on pavement so the right rear can start moving the truck forward which causes the back left to start rotating and eventually start working. Again, it doesn't do this in reverse, that gear is still working perfectly.
I'm completely confused at this situation, I have no idea what's going on. I'm worried that I might be needing a new transmission.
