Not Starting!
koppenhaver
Jacksonville Fl
okay so i went to work this morning my truck started up and drove fine, when to leave work it started and drove to the gas station, shut it off came out of the gas station and it would not start! acted like it was flood so i let it sit, still nothing so i pushed it into a spot and left it there for a few hour came back still didnt want to start then when it finally cranked up, my idiot friend forgot to release the E-brake and it shut off again, could not get it started after that.
i cracked the fuel line coming in to the carb to make sure it was getting fuel, and it was, i tried starting fluid and all that but still no joy.
Please help!!!
Disconnect a plug wire and check for spark. The TFI module on the distributor is a common problem.
