daddy-justin
- Jun 20, 2008
I was driving my 88 Ranger 2.9 the other day. It had started making occasional noises lately that sounded like it was coming from the transmission, transfer case area. When I would let off of the gas, it sounded like someone was stomping with their shoes on the bottom of the truck about 3 times. Sounded like a muffled thump when I would let off of the gas. It only happened after the truck was warm and not all of the time.
I was driving down the street and I heard a bang, truck stalled and I coasted over to the side. Truck started right back up but rear differential was broken out. Looking back, my thoughts are that the transfer case locked up and since the truck was rolling but the transfer case was locked up, it broke out the rear differential. Not seeing any damage and not really knowing what happened, I locked up the front hubs and engaged 4 wheel drive, since I had no rear wheel drive and started to drive home. About 2 miles from home, the same bang and engine stall occurred. Yep, I broke out the front u joints on the half shafts. Now, I had no rear drive and needed to be towed. Not a good day.
Manual transmission was rebuilt about 20k ago and I have had no issues with it at all. Does this sound familiar to anyone and am I on the right track? I found a used transfer case that I was going to put in. My thoughts are that the bearing seized in the transfer case and that is what caused it to lock up temporarily. Once I started the truck, everything seemed to work fine, except for the broken parts in the rear and front.
I just drained the transfer case and it is full of good ATF fluid and smelled like ATF. no burning smell. Thinking maybe the transfer case oil pump stopped pumping oil and might have seized the bearing. Could the transmission be the problem,??Clutch?
Any thoughts would be great. What could cause this lock up?
Justin
Justin
