DangerangerHD
- Sep 18, 2008
Ok, I just put in my new djm drop beams (94 2wd 2.3l) and it pulls HARD to the left. The only things that are different in the front end are new stock height springs, the drop beams, and I had to flip the sway bar brackets (connected to ibeam) because they wouldnt set flush against the beams unless I flipped them, which I'm pretty sure (but not 100%) it said to do in the djm instructions. I didnt change the setup on any of the steering linkage. Any ideas what is wrong, please dont just say "get it alligned" because this is a budget project and I hate to just throw money at problems.... that is unless you've been through this before and had the same problem solved by an alignment.
Thanks
DangeRanger
Thanks
DangeRanger
