not much height
polkat
northern Wisconsin
Gave the torsion a twist and its not much higher than when I started one bolt is maxed the other is little over half the rear sits at 35 1/2 and the front is at 34 1/8 (bottom of fender to ground) it wont let me go any higher the one side thats maxed the key is very close to hitting the frame work the other is not even close I wish I would have wrote down my starting measurements but it probally only lifted it 3/4 to an inch. could there be any problems with the other components such as: bad/ worn shocks ball joint play? it drives great no pulling clunks bangs nothing to indicate bad suspension parts. I may take the bolts out and check if they are the same lengh and put in longer ones. any body have any imput ?
