lrdg
- Feb 25, 2008
- Age
- 72
- Automatic
I’ve been lurking around here for a couple years and seem to ask a question about once a year. So, here’s 2010’s question. The truck is a 1984 Bronco II, engine is stock 2.8 with less than 100,000 miles since rebuild. Ignition is duraspark, the distributor was purchased new (rebuilt?) from NAPA, and the control box was out of a yard. The Carb is a 2150 / 1.08 off a 1978 Mustang II. When I did the conversion I was very happy with the possible exception that it seemed like it should have had a bit more top end. For that last few months I have lost the bottom end. It will only crawl away from a stop, such as a stop light. It will just barely go up a hill . On the flat it will run along 60-65, no problem. It feels for all the world like a timing problem. I have adjusted timing repeatedly. I have set it between 8 deg. and 15 deg. BTDC with the light, I’ve tried setting it by vacuum, I’ve tried adjusting it by ear. I cannot get it. A couple days ago I found the vacuum modulator on the tranny was sucking ATF so I changed that out. Just for grins I stuck a 2150 / 1.21 on to see if it made any difference. It didn’t, but I did find that I don’t really want to do that in the Arizona desert ion the early afternoon. I am a shade tree sort of guy and have built engines so I’m not completely ignorant but as its all sort of hobby there seems like always something I’ve missed. Any suggestions or similar experiences?
Thanks!
Thanks!
