Not Another CTOR Build
What troubles?
I put my doubler back together. And every time I have used it I always seem to have a problem with the low range box. When I am not in double low it seems to pop out of engagement in the crawl box. Its sounds exactly like putting a manual into gear without depressing the clutch (the gear grind sound). I have to have the crawl box in the 2hi position to get power transfer to the tcase. If its in the 4hi position its acts as if its in neutral, I would have figured 2hi and 4hi position would act the same. Double low seems to work fine and holds position. I seem to only have a problem holding 2hi. It doesn't matter how I adjust the linkage its always the same result.
I was thinking maybe the doubler shaft isn't sitting just right in the crawl box. Like maybe i need to put a spacer between the shaft and the tcase input to hold the doubler shaft further forward into the front gear set of the doubler?
Doublers back out
I tore it down tonight. It appears the rod the shift fork rides on was misaligned to the doubler plate. So it sat at a slight angle instead of straight up/down.
I found a small steel sleeve that fit tight over the rod, so i welded the sleeve to the doubler plate to relocate the rod. Hope tomorrow to get it reassembled, installed, and tested.
Well my instrument cluster was all messed up lol......it would read way over on the oil pressure and the temp gauge was always running really hot to overheating most the time. Fuel gauge didn't read accurate (way to full). And my dash lights were always on regardless if the switch was on.
So I bought a tir-gauge set (oil, coolant, amps). Installed and hooked up the oil, coolant. With the oil, coolant sensors unplugged my other gauges in the cluster now work fine :teehee:. And I have 40-60 psi all the time and temp never went over 180.
The very out edge of this section of the gear had adverse wear, must have been where the gears were grinding.
Pic is not of my stuff, just the only pic i could find quickly of the front gear set.
The rod the shift fork rides on was misaligned with the doubler plate. Repositioned on the plate and it seems to work flawlessly.
Looking at buying a new tow rig, got this for a 48-72 hour test drive this weekend. Going on a 350 mile round trip wheeling and using the truck to see if I llike it.
looks good, How did you like Rocks and Valley offroad? I'm thinking about taking a trip up there sometime soon...
awesome and the hospitality was top notch
Pulled the truggy off the trailer and put the doors on. Had to bend both drip rails up in order to close the doors. Bounced both sides off some trees. But I was looking at the underside and I'm gonna need two new diff covers as both are dented in pretty bad. And I bent my Right side radius arm. Not a lot, but just enough to notice the curve.
And I have 3 flat tires from all the bark that got shoved into the beads from running python.
cannot wait to get back to rocks/valleys
damn lol.
nice vids. Definitely looks like a fun place.
My local club had its annual event this past weekend, here's some shots
Trans is out and getting a new slave cyl. a new starter, and building a set of
one down 3 more to go
I was bored............and the beadlocks are all done. That's 6 feet up the tree.
Sweet! Love the build....I am starting to feel inspired to build my own!
