Not Another CTOR Build
drilled all the spot welds and it falls off
if you'd run a 3 link you'd have to have full hydro, unless I'm missing something.
pics look good-those are 35's no? I guess you do have a decent amount of lift but I'd say the clearance looks fine with the engine crossmember.
the steering system and a three link have a huge conflict yes. The hydraulic steering system eliminates the steering system from conflicting with the suspension. Although you are still using a track bar as in the original radius arm system so you can run conventional steering.
The nicest thing about the leaf system is that you lose the track bar. You have better control over the front of your truck over the rough stuff.
oh got some stuff done......just about ready for the Badlands May 2nd.
Got the cage painted and welded in some more bracing etc....Cage is down for now till after the Badlands. Got the Pass Seat mounted and the 5 point i got from General (thanks Buddy) mounted up. Also mounted my CB to the top of the cage at the cieling.
Heres a shot messing around with Holshotracers Rig
I also worked on my rear and front bumper. You can see in the above pic how wide the bumper was. I took about 5 inches off each side.
then a clubmate made me some D-Ring mounts so i got those installed
got two in the front as well
Then i had some diamond plat laying around so i added that to the bumper as well
Next i'll be getting 2 DOT approved Fire Extingquishers to mount on the cage in the B2 as well.
bought two 2 lb Extingquishers
aproved by DOT and coast gaurd,
covers elec fire and flammable liquid including gas, gonna mount both to the cage
newest mod............
Cost me all of $15 and about 20 minutes of my time.....need to figure somethig different for the handle. The linch pin works enough for me to try it out around the yard (Fawking Awesome). I'll have to stop at TSC or Ace and find somethign better to use.
i searched the forum, and the tech library. Was suprized not to find any info on how or even pics
is this a hand throttle I'm lookin at?
with crossover steering you still want the trac bar.
well if you want to comfortably cruise the freeways anyway. especially the shithole detroit ones.
i know i will be jealous if you run the springs unmodified from the original setup and dont fawk them up on the pink.
i was busting the fawkers in my yard. of course...v8 ext cab...so weight was an issue. that and i had a lil more unsprung wt. busting the yokes was the worst part cause i actually had to buy a seal and yoke and joint. i hate buying shit:annoyed:..
and i cant keep my front pinion from leaking since the second one got splattered.:icon_confused:
good luck at the badlands...i dont think you need any though. seems like you got er going good.
oh its getting so damn close now, i can't wait. It better happen soon though the cost of the trip just keeps going up.
awesome, I researched those a little bit a LONG time ago. never got around to doing it. your trip is coming up pretty quick, I won't be able to make it. I should comfortably have all my work done by memorial day weekend, maybe I'll make it over there then.
we leave may 2nd and return may 4th
well the b2 got some new front axle seals today....bastard of a job for sure. Took out another tranny mount, but the u-pull-it hooked me up for $4.99 on a good used one. 3 more days befor the B2s hardest test off-road WOOT
