black_demon69
ok it is a 98 ford taurus 3.0l. if i bypass the high speed cooling fan relay and the A/C clutch relay it will cool 38 to 40 degrees out of vents and pressures are nominal on both the high and low sides.. however a/c will not come on with relays in place and cooling fans cycle with engine temp. i have replaced relays and tested relays in another vehicle and they work. fuses all check good. so as you can see now im stumped.
