- Aug 17, 2007
- central ohio
- 2.5 (4 Cylinder)
- Automatic
- Tire Size
- 235/70/16
- My credo
- the grey-t escape
'97 S10 blazer 4dr 4x4, 177,000 miles. found rear diff oil low last august, pumped out what was in in through the "add" hole. refilled. noticed about a month later that the drivers side axleshaft seal was leaking. today was "maintenence day" for the blazer, front end got new cailpers, pads,rotors and steering fittings greased. back end got new axleshaft oil seals on both sides, cleaned shoes off on drivers side that had oil on them, painted rear drums and diff cover, filled with oil when done. i was shocked at the wear and pitting on the spider gears, ring and pinion are fine. there was some wear on the axles where the bearing and seal ride. could this damage be due to oil level being low? seems many dont think about servicing the differential. when i changed the diff oil in the ranger all the gears looked great, granted the ranger had only about 125,000 miles on it at the time, this gearset has 177,000 miles on it. going to run it as it is and see what happens, have a parts blazer with 3.73 gears that i can swap axles with if needed. only downside is that i will need to do both front and rear swap, the "good" blazer has 3.42's id rather have 3.73's but swapping that front axle is a major job. and i ought to see what that gearset looks like, the parts blazer had 198,000 when it was parked. it does have the limited slip carrier though. maybe i'll rebuild it this summer and have it on standby.
