5.0
Quick disclaimer - none of the following pics are mine. They have all been borrowed from somewhere off the internet.
Ok, I've searched and read, and I still don't have a firm grasp on which mounts are the best for me.
The engine I'm wanting to swap in came from a '92 Thunderbird, and I want to put it in my '97 2wd 2.3 truck.
I *think* I want to use the Mustang mounts or the Advance Adapters mounts. Do these mounts bolt to the block, then directly into the frame with no extra required parts? Do any new holes need drilled in the frame for either mount? Will these mounts position the engine lower in the frame than other mounts?
Here they are...
and
Then there is the plate that can be made at home. This plate will bolt to the engine block, then to the top of a stock 4.0 motor mount? But does it sit the engine higher in the frame?
I have no idea how these are used. Does anyone have a pic of them installed so I can see how they work?
And lastly, this is the oil pan on my engine. Is it the correct one for the swap?
Here they are...
and
