Noise when driving in 4Hi
2000offroad
Hi need some help.when driving my 2000 ranger in 4 high im getting a humming or whining not sure if it is in the transfer case or elsewhere anyone have a idea.thanks
Welcome to TRS :)
2000 Ranger could have "Live Axle" always locked, up front, or PVH automatic hubs, or Manual hubs(added on)
Which do you have?
Good upgrade :)
So leave the hubs Unlocked and shift into 4high to see if whine is still there, if so then noise is from transfer case or front drive shaft/axles
Then put in 2WD and Lock the front hubs and see if whine is there, if so then not transfer case so you are down to front drive shaft/axles or...........new hubs, when Locked
with hubs unlocked in 4hi its not as bad queiter in 2wd with hubs locked in no noise with hubs locked in & in 4 hi under deceleration its real bad
Wheel bearings or bearings in the front diff.
could it have anything to do with the driveshaft or electric shift motor.
No, drive shafts problems are usually described as clicking, not whining, noise
Electric shift motor is only used when shifting between 2wd, 4wd, 4low, otherwise it is OFF, so can't make any noise
Whining or hummmm, is usually a bearing of some kind
Since the wheel bearings are used all the time, being in 2wd or 4wd wouldn't matter, noise would be there all the time.
You do have CV joints on the front axle so they could be the issue.
Read here: http://www.therangerstation.com/forums/showthread.php?t=12208
thanks ill take a look what if i lift the truck off the ground and put in 4 hi would it be easier to locate
would it be easier to locate if lifted the truck and put it in 4 hi
Maybe, if you lift up all 4 wheels :)
If possible lift front by aframes so wheels/axle are at normal height, not hanging down
Did you ever find out what it was? I just brought a ’92 Ranger home tonight. It too has a whine that I’ve never heard before and I suspect (for other reasons), that it may be stuck in 4 HI.
