No unkeyed power for radio.
Shoebox72
Seymour CT
My 95 ranger had a non working stock radio when I got it. I just went to install an aftermarket radio with the proper adaptor plugs & face but I have no memory power for the clock & stuff.. The radio is totally off till I turn the key on. So Im wondering if there is a fuse for the constant 12v source? & what it would fll under.. Thanks fellas!
That sounds like normal operation.
Constant power keeps the clock running and saves the preset channels.
Check the fuses. 12v constant should be the green wire with yellow stripe.
Whoops, misses the word "memory" in there.
Fuse 29 under the dash feeds the constant KAM power to the radio.
