no turn signals
gb2003
i have a 90 ranger and the turn signals quit but i still have flashers. the fuses are all good so i guessing the switch is bad. any suggestions
I actually had the same problem....but try this, might sound kinda ridiculous heh but swap the 2 Round fuses that should be under your steering column
that fixed it for me....idk how, but it did
I think the round fuses you are referring to are the flashers that blink the lights.
lol yup
I replaced them a while ago when mine didnt work....didnt fix the problem, then when i took the viper alarm outta my truck i figured "What the heck..." and swapped them.....somehow, that fixed it...:yahoo:
thanks for the quick replys. i think i just have one flasher in the fuse box.my flashers still flash. is there a separate flasher for the signals ?
when i turn the the signals neither right or left will light up.
(on my truck atleast) the flasher for the hazards is on the back side of the fuse block. the one for the turn signals is on the front. odds are it has burned up.
thanks ill check it out tomorrow
yea i had the same problem and changed the flashers and it was fixes:icon_pepsi:
thanks for the help it turned out to be the flasher. i didnt see the other one til this morning.
