karsyn28
- Sep 14, 2013
Hello,
I have 94 ford ranger 4.0 xlt. It will run if i spray contact cleaner down throttle body so it has spark. has new fuel pump and regulator. fuel pressure is at 35 psi with key on. key on and not cranking the fuel pump never stops running. i have switching voltage coming from cam sensor. i cant pull codes using the on board diagnosing system. the check engine light does work. before is by a used pcm any ideas?
thanks for any input
