No start
RCranger99
Hey guys I need some help here. I just got my truck back a few days ago from my parents and it doesn't start any more. My dad thinks it is the negative ground terminal as it was pretty old and worn out.
So i cut the old one off and striped about an inch of the wire off and connected a new terminal. When I go to start I only get one click and nothing else. The lights and radio still work.
I was pretty sure it was the ground wire as before i changed the wire it just clicked once i figured ok i have a bad connections so it put a little water on the terminal thinking that would complete the circuit. It did and it started but that trick no longer works.
It is a 1996 4.0 5speed 2wd.
Also it is a bran new battery.
Any ideas guys.
Have you checked and cleaned the positive wires? Have you checked the wires at the starter end? Is the starter loose?
Richard
hey
did you try to start it with jumpercables??? dead battery/connections {which you already got started on} is first place to check on a no start..
:icon_thumby:
