No start what am i missing?
Final777
Ok im really stumped again. I have a charged battery, new starter and relays. I have spark, the fuel pump is coming on. The engine is turning over great, but she still won't start what am i missing?
Compression possibly too
hit it with a shot of starting fluid
It needs three things... well four.
Fuel... at the proper pressure. Have you checked that?
Spark... this needs to be timed properly.
Compression... have you checked it... even a single cylinder?
The 4th is injector pulse... your pump can run all day at proper pressure... if injectors don't pulse... it will never run.
Have you pulled a plug? Is it wet indicating a flooded condition?
'86 has 3 engine options (well 4 if you include diesel but that's very rare), which one? They all had the TFI ignition so I would definitely look into if it has spark or not... if not probably the TFI module which also gives the rpm signal to the engine computer for injection I believe...
