mazdab40004x4
Hi Folks -- I've got a 94 B4000 (4.0 OHV) that won't start. For a few weeks it was hard starting -- I'd turn it over and over with no luck, and then wait a minute or two and it would start. Now it won't start at all.
I think it's either the fuel pump or the connection to the fuel pump. I turn the key to on and the fuel pump relay clicks every time -- good there. I've also checked the inertia switch and it did not seem tripped (the button was already in the down position and since the relay clicks I didn't think that was the problem). I listen for the fuel pump itself and it kicks on, but not every time I turn the key -- maybe only one or two out of 5 tries. So I'm leaning towards either a bad connection to the pump or the pump itself is failing. Am I wrong here? The pump is supposed to run for a few secs every time you turn the key, right?
Planning to replace the fuel filter on it tomorrow as I have no idea when it was last changed if ever and I just want to rule it out before I go doing anything with the pump.
Anything else I should be looking at tomorrow to figure this out?
Thanks -- Jeff
Thanks -- Jeff
