msdhanda
- Sep 7, 2016
- Automatic
Hi everyone.
I've a 2.9L 1990 ford ranger automatic transmission with 4WD. It died it on me while on road. It keeps cranking but never fires up. I suspected bad fuel pump so I replaced it still no luck. I have power at fuel pump connector do that rules out electric issue and also I unhooked fuel lines and it's squirting fuel do that takes off fuel pump as issue. I tried spraying some in intake manifold still not firing up. I have power at ignition coil and from there to on top of distribution box. I can't come up with anything. Need your advice. Is ECM gone bad? or what else should I check?
Suggestions.
Thanks
Suggestions.
Thanks
