This is for a '89-'90 DIS 8 plugger 2.3
Replaced both coils, all plugs, wires, DIS module and computer. The CKPS had the seperate green wire broke, fixed it and still no spark.
The Relay - Powertrain Control Module is located:
Under hood, driver side, front side of wheelwell, rear of starter relay, below power box, under relay cover, mounted on fenderwell
Ok you said driverside......don't you passenger....cuz i'm not finding anything on the driverside....I found 2 plugs under the fuse panel.....are those it?
For
